I have an avi file that is actually an mpeg file(the extension is avi but a properties in windows media player says it uses a mpeg codec). When i play the file in windows media player it says the file is 1 hour and 2 mintues. When the file gets to that time it continues to play for a further 8 or so mintues.
Now my problem is when i try to convert the file to mpeg2 in TMPGEnc express 3.0 the finished product freezes at 1:02 and continues to play for 8 or so minutes with no sound and picture frozen. Is there anyway possible i could fix the file to get the right timing.
No my capture card has bad results so i aquired this file off someone else.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator offline
Hi, you may or may not be talking about WAREZ.
Please read the rules and AUP before posting if you have
not already done so. They can be viewed by clicking [HERE]
Thanks,
Mod Offline
convert compressed avi files to mpeg without increase in file size?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 7Last Post: 2nd Nov 2011, 05:29 -
autogk wrong file size and cropping
By codemaster in forum DVD RippingReplies: 5Last Post: 5th Dec 2010, 08:09 -
Wrong image size ratio after AVI to DVD encoding
By video34bgi in forum Video ConversionReplies: 2Last Post: 22nd Jun 2009, 10:45 -
Wrong File Size on Ripped Files using AutoGK
By tommyjv in forum DVD RippingReplies: 4Last Post: 17th Nov 2008, 12:21 -
Why is this wmv file the wrong size?
By abisti in forum Newbie / General discussionsReplies: 8Last Post: 5th Feb 2008, 18:14
