  1. Member CaZeek's Avatar
    Aug 2003
    NJ, DC, or Baltimore
    Hey,
    Does anyone know of a program that will allow you to select audio/video inputs separately w/ AC3 and MPEG support and play them together? Vdub would work, but I don't know of a way to support MPEG and AC3 simultaneously. Any suggestions?
    Thanks!
  2. Yes. Media Player Classic has an excellent dub feature which is enabled automatically if both the m2v and ac3 have the same filename.
    For example:
    Sparky.m2v will automatically have dubbed audio from Sparky.ac3
    or
    if you have Scruffy.m2v and want audio from ScruffyAudio2.ac3 you can manually set up the dub since the filenames are not the same. (Or alternatively you can rename ScruffyAudio2.ac3 to Scruffy.ac3)
    HTH
    -free
  3. Member CaZeek's Avatar
    Aug 2003
    Thanks a lot, this is working perfectly for me. That same file name feature is extremely convenient too
  4. No problemo. I'm glad you find it handy
