  1. Just wondering if anyone knows why tmpgenc doesn't show the "shutdown pc when done" option. It used to be there and now its just not there???
    thanks
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I believe that it only appears when you do batch processing. I guess one workaround is to add your job to a bath (even if you are only doing 1 encode) to make it available.
    If in doubt, Google it.
    Mar 2004
    London
    You have to use the Wizard through every step, then when start encode it will be there. (same for the bitrate calculator)
  4. Thank you both,
    Saving as a batch worked, using the wizard didn't.
    Should I use shampoo.
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
