ok when i try to back up some dvd's from ones that i download ( movies that i already own) , when its finished and i take it out and play it on the dvd player for my TV it has like a problem that looks like what would be a VHS tracking problem ?? its not the burner/program/or media as other movies came out just fine, AND when i play it on my dvd player on my PC its just fine. i am thinking possibly that im not doing somthing right for specific file formats... has anyone had this problem ?? and can help??? i use a DL burner, and usually two well known brand programs to do the burning.
Why download a bad copy of a movie that you already own? Just follow any of the guides here to rip/shrink the disc you have (?).
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
the reason is we just moved from over seas and our stuff is in storage and wont be here for another month!!!!! and the copy i dl is not bad, it works fine on my pc but has a wierd tracking problem when i play it on the dvd player. plus a couple other movies came out just fine and they play fine on both the PC and the dvd player its just certain movies. Do zones have anything to do with it????
if i had my dvds here i wouldnt be dling them, im not that stupid geez. -
Could be an interlacing issue with the dl-ed copy. Your PC plays it progressive (a frame at a time) and the DVD player/TV interlaces it (plays one field, then the next ...two fields make up a frame).
Try re-authoring it and make sure you've selected interlaced and not progressive playback
thanks man, where would i try that at though? in the top menu options?
trouble backing up dvds to external hard drive (on PC)
By duquesne in forum Newbie / General discussionsReplies: 4Last Post: 25th Dec 2010, 09:32 -
Hello I am having trouble backing up a dvd
By Seekyr in forum Newbie / General discussionsReplies: 6Last Post: 10th Dec 2008, 12:14 -
Trouble backing up Mr Woodcock
By dor in forum DVD RippingReplies: 3Last Post: 18th Jan 2008, 14:18 -
Trouble Backing-Up DVD...
By LCE in forum DVD RippingReplies: 7Last Post: 1st Nov 2007, 01:38 -
'backing up' dvds
By nobbyiscool in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2007, 21:25
now there's a novel idea
