I have some Divx 5.0 files that will play fine on the computer, but when played on DVP 642 the colors look like red and blue are switched. Any ideas?
Thanks,
I'll start with the easiest... does anything play OK on the player? If not, and you are using component video connections, make sure that you have not swapped two of the three leads.
check the forum for the fix for this. i know some other folks had some issues similar and fixed them with cable switching or menu
heres what i do to fix that problem
go to the system menu,/video options/tv standard, and then switch between multi and ntsc,
each time you get that red and blue sceen, try this, has worked for me every time for some reason
Problem with philips dvp 642/37 after choosing progressive scan option.
By vinland in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Jun 2010, 20:21 -
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 13:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 03:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 17:26 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 15:36
