hello everyone my computer is playing about at the minute when i start a program it just knocks of screen goes blank then comes back on again,iwas wondering if i reinstalled xp pro over the top of my exsisting version of xp pro will i need to reinstall service pack one again.any help is apreiated![]()
one problem solved can solve alot of problems
Installing winxp over winxpsp1 will result in lots of errors.
whats the best way to sort out this problem johns0
one problem solved can solve alot of problems -
Do a fresh install deleting the partition and installing onto a new partition and then install sp1 unless you know how to create a winxpsp1 intergrated cd then you can install over your old partition,search google if you want to learn how to make a winxpsp1 cd.
thanks johns0 will give it a try
read how to do it here (with sp2):
http://www.windows-help.net/WindowsXP/winxp-sp2-bootcd.htmlHELL AINT A BAD PLACE TO BE
Reinstalling Windows XP
By wulf109 in forum ComputerReplies: 17Last Post: 2nd Apr 2012, 19:52 -
Reinstalling windows vista
By Sportster Freak in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2009, 23:23 -
Question on reinstalling XP.
By dimtim in forum ComputerReplies: 3Last Post: 19th Jun 2008, 08:02 -
reinstalling svcd2dvd
By marcusden69 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 16th Apr 2008, 07:25 -
Uninstalling or reinstalling nero
By b3cko in forum ComputerReplies: 3Last Post: 10th Jan 2008, 09:37
