Sorry if this is a dumb question. Whenever I open VirtualDub, the Input and Output windows are both pretty big. I have to first resize the Input to very small, then do the same to the Output window. surely there is a way to 'remember' the window sizes?
right click on each window and select a window size (%)
edit...sorry...I re-read your post and realize that you already know how to do this. I don't know how to make it remember the size so sorry but I can't help. -
Sorry for reviving this old thread, but after 10 years passed, I still don't see any window size controls when right click in webcam capture preview window in VirtualDub. How do I fit VirtualDub window to captured preview size? Is there a command for that like "Fit window to preview" or "Autosize capture window"? Dragging window corners makes inaccurate fit.
The first paragraph may give you some info:
http://www.virtualdub.org/blog/pivot/entry.php?id=65 -
Thanks, but it doesn't mention that particular feature, only dragging corners and resizing preview window, but not VirtualDub's window autoresize. Meanwhile, its very convenient as anyone can try with free AMCap versions.
Unable to play asset in preview window
By gstewart in forum Newbie / General discussionsReplies: 2Last Post: 3rd May 2010, 19:04 -
Vegas Preview Window is choppy--please help!
By duderdude2 in forum EditingReplies: 8Last Post: 24th Mar 2010, 14:29 -
No Video in Preview Window.
By therearenorules in forum Capturing and VCRReplies: 0Last Post: 18th Jan 2009, 14:21 -
preview window plays too fast in various software
By spiritgumm in forum EditingReplies: 4Last Post: 26th Sep 2007, 16:48
