Hi everyone,
I have a VERY annoying problem.![]()
NONE of my auto complete functions work in IE. I've gone into the Tools > Internet options > content - setting box and turned ALL the auto complete options on and nothing works. Except for the option to "rememeber" the password popup whenever I log into a site. I click "YES" and then it loads the page. But the next time I go to that site it doesn't fill in the box with the username/password as it should. It works just fine on my other computers just not the one I use the most. I made sure that none of ZoneAlarm settings will interfere. In fact it's set up identical to this computer so I know it's not Zonealarm. I can't think of anything. I'm ready to pull out my hair on this one. It's been this way for so long that I can't remember if it ever worked. I know some of you will say "Use Firefox/Mozilla but I like my IE![]()
I'm open for any ideas.
Thanks for your help.
This from MS. http://support.microsoft.com/default.aspx?scid=kb;en-us;885180
Looks a little convoluted, and I don't see them explaining why it would quit in the first place. Hope this helps. -
Thanks a million redwudz.
That didn't help exaclty but I did figure it through that link.
The part that says "Protected Storage" I had that turned off through component services via admin controls. I thought that was for Norton System works...
All this time I thought my windows was jacked and I turned it off. I knew I messed it up on purpose by accident.
XviD4PSP & Avidemux Doesn't work for me anymore.
By The_Jelly in forum Newbie / General discussionsReplies: 15Last Post: 14th Mar 2012, 08:05 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
dv capture and playback doesn't work anymore (except in quicktime)
By richardlode in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Jun 2008, 01:22 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
Philips DVDR7310H: search (Guide Plus) doesn't work anymore
By Monco in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Aug 2007, 12:05
