Hi
I am running XP Pro SP1
I have run the latest beta a couple of times and each time I have had the following error at the end of processing:
Type: System.IO.IOException
Source: mscorlib
Message: The process cannot access the file "C:\Temp\SVCD2DVD\menu\MenuMuxer.exe" because it is being used by another process.
InnerException:
StackTrace: at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.File.Delete(String path)
at SVCD2DVD.e679539bc4bbd8b5.865d1dce05e7a87c(String c7faa4629ea73ace, Boolean 1ebdb8fb1e9908a0)
at SVCD2DVD.d3764d4f1e921081.a727fa5530af9286()
at SVCD2DVD.d3764d4f1e921081.f81783e1b359ffc3()
The program has made the Audio and Video TS folders ok and when I burn them the movie plays ok complete with menu.
mesaboogieman
Ok thanks. I will look into this. Can you email me a log file where this happens?
Thanks for the log file. I shall have this fixed in the next build.
SVCD2DVD Error when encoding menu??
By gsmb in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 23rd Feb 2011, 13:44 -
Error on Startup SVCD2DVD 2.5
By jenevans33 in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 04:05 -
Error reports in SVCD2DVD
By deoldeprinter in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 5th Nov 2007, 21:03 -
svcd2dvd error urgent request
By dvds2u in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 10th May 2007, 09:22
