I searched and did not find an answer to this question. I have an oem version of Nero 6.0, with serial number. I upgraded to 6.3, and everything worked fine. Now, when I upgrade to 6.6, it tells me that I have an invalid serial number. I checked the FAQ's on Nero's site, and it showed something about looking in the registry for the serial number.
I looked, and found two nero serial numbers. One for 6.0, and one for 6.2. Anyone have any ideas on how to get this to work???
Rob
Uninstall all Nero versions via the control panel applet. Then open regedit and remove any remaining references to Nero (and "Ahead" if Nero is your only Ahead software). Delete entire keys. This may take some time ...use the "Find" tool.
Then reinstall 6.0 and try the upgrade again. -
go to the nero website and download the NERO CLEAN TOOL. then reinstall NERO burn.
The problem with the uninstall apps is they seem to invariably leave some traces. Going through manually guarantees that it's gone.Originally Posted by budz
But it's a decision he has to make depending on how thorough he wants to be. -
Nero Clean Tool comes with a registry tool to clean up the mess. I would recomend using the Nero tool after uninstalling 6.xx.
try to use any of the two serials
hacking the Net using typewriter :D
Updating X264vfw
By hech54 in forum Video ConversionReplies: 1Last Post: 30th Jan 2011, 09:16 -
Updating ffmpeg
By whoisquilty in forum ffmpegX general discussionReplies: 3Last Post: 4th Apr 2010, 19:28 -
Editing and updating
By Jomapil in forum FeedbackReplies: 2Last Post: 15th Feb 2009, 06:35 -
updating windows xp
By aruwin in forum ComputerReplies: 12Last Post: 15th Oct 2008, 15:00 -
updating drivers
By romanstopme in forum ComputerReplies: 7Last Post: 9th Oct 2008, 13:09
