    Nov 2001
    USA,Iowa
    ok i notice on kazaa ill download some movie file and it will end up saying vite-divx or file made by vite and the thing is there real good divx movies the best i think ive seen when i try to search on google to figure it out if vite is a person or a program or what i get a lot of divx sites and french web pages DO YOU KNOW WHO OR WHAT VITE IS!!!!
    /////////////////////////////////////////////////////////// Put your finger here! ----------> x x //////////////////////////////////////////////////////////////// Ha Ha now you have to clean your screen
  2. Member adam's Avatar
    Sep 2000
    vite is a divx release group. If you want to see what movies vite releases and when they are released check the divx release section at http://www.isonews.com.
    Nov 2001
    USA,Iowa
    thanks much i was going crazy
