Hypothetical situation...
Let's say that one has DTS audio discs for the theater (with the .AUD files and all) and converts the 5.1 mix to 5 mono uncompressed wav files. The bass is all taken care of too. So now they've got 6 mono wav files, maintaining the quality, but want to convert them to just 1 single 5.1 wav file but without any type of compression, i.e. .ac3, .mp3, etc., but also wants to fit this file on to either a few blank cds or dvds, or one blank DVD9, for playback in a dvd player. how do you go about this? how can these 6 mono files be converted to 1 wav file, still be multichannel and uncompressed, and be compatible with a dvd player? a multichannel pcm or wav file has been unable to work on a few tested dvd players. what is the solution without compression?
multichannel.wav
pcm. 16-bit. 44,100. burned to a cd-r. FAILED to playback on dvd player burned either as data or audio.
????? any help would be great! thanks.
Results 1 to 19 of 19
2 hours uncompressed 5.1 wav files going to need several disks
you can't far as i know ... it will have to be compressed"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
If you want to compress but without loss you can use the FLAC codec. It is a lossless audio codec. It is computer based only though, it will not be playable on any stand alone device that I know of. FLAC compresses between 2x-3x which can be very useful for archiving audio.
MLP could be the right solution for you -> authored in a DVD-Audio it should over the best quality with less space consumption :P
Surcode DVD-DTS is being used to do this.
if you take 16 bits and convert it to 24 will it affect the quality of the sound negatively, improve it a bit, or not do anything and just waste space on the file size? i would imagine it would waste space because the original master isn't being used, rather an already compressed form. -
Question was:
Surcode DVD-DTS is and that is fact a lossy encoder, MLP not (but it is expensive like hellwhat is the solution without compression?
There only a view alternatives, one is to make a DVD-Audio using the uncompressed WAVs with discwelder (the playing time would be extreme short because of the 6 channels uncompressed), or compress them lossless with MLP (the only lossless encoder inside the DVD-Audio standart) -> the playing time will much longer.
Iīll guess itīs the best opportunity to chose a lossy format and make a DVD-Video out of it!
In my opinion Surcode DVD DTS then would be the best choice!
bye Daphy -
First, isn't DTS itself a form of compression?
Second, why not just leave it as DTS... the standalone could handle it.
Third, Did you say you wanted to put this as 5.1 on CD? As in audio CD? -
yes, but lossy -> he asks for a lossless solutionFirst, isn't DTS itself a form of compression?
Second, why not just leave it as DTS... the standalone could handle it.AUD is not exactly the same as DTS, definitivl no home DVD can handle this filesDTS audio discs for the theater (with the .AUD files and all)
as a 6 channel WAV, it wonīt fit to the audioCD standart, but this question should be answered by kaotekThird, Did you say you wanted to put this as 5.1 on CD? As in audio CD?
bye Daphy -
DTS theater disks (which are on cd) (AUD files) can be converterd to wav and then to anything else ..
the theater compression is different than the home dts compression .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
the theater disks ONLY play on a DTS-6D or 6AD cinema system, which is a standalone hardware unit..
but there is a way to convert the content to wav on a pc .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
you think about the APT-X100 DTS Decoder,
yep, with this program itīs possible
bye Daphy -
yes - it works perfect
i've already gotten it all to work. now i'm just going to sync up this big ass dts file with the movie and burn to a dvd9.
damn. the .dts file gradually goes out of sync about 20 minutes in to the movie. any help?
it has to be locked to the dts time code on the film as they are not in sync otherwise .. you have to (if it happens) re-sync them manually if you don't have a portable dts sync generator handy ...
Using Vegas is about the easiest way to re sync audio"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
good i have sony vegas but how do i sync it up? is there a guide here ont he site? if there was some way to just squeeze the track, you know? so it doesn't drift off.
the easy way is with vegas i think
put the movie on the time line and drop all the waves on the time line in thier respective channel spots ...
group all wav files together ..
hit control and drag the end of the audio so it matchs lenth of video .
fine tune and adjust as needed (turn off frame quantization for this)
save out new wavs , select render to mono wav (will save and auto name each channel)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
DTS-MA Converted to DTS-ES MAtrix?
By MrPaulJ in forum AudioReplies: 2Last Post: 23rd Oct 2011, 06:55 -
Creating a Blu-ray Theater Demo Disc w/ DTS-HD, TrueHD & LPCM
By scubasteve2365 in forum Authoring (Blu-ray)Replies: 6Last Post: 29th Jan 2011, 11:00 -
Why did my DTS track get converted to 2 ch. PCM ?????? Please HELP :(
By Spdngblt56 in forum AudioReplies: 2Last Post: 12th May 2010, 03:17 -
Help me create a DTS, DD, THX - DVD For Home Theater Demo
By hometechinc in forum Newbie / General discussionsReplies: 1Last Post: 31st Jul 2008, 17:33
