Hi, I downloaded a DVD movie and after I burn it to watch on my DVD player, it say that it have an error wrong region code. Is there a way for me to fix it so I can watch on my DVD player?
Results 1 to 9 of 9
"The secret of genius is to carry the spirit of the child into old age,
which means never losing your enthusiasm."
- Aldous Huxley -
Check to the left for DVD hacks and do a search for your DVD player make and model. A lot of players can be hacked pushing buttons on your player and remote to make them region free. Also there is soft ware that can make a disk region free.
Cheers -
if i'm not mistaken you could run the movie through dvd shrink using no compression. dvd shrink would then make it region free or you could use dvd decrypter too. anyone can correct me if i'm wrong about this.
Originally Posted by budz
So I just open the files in DVD Decrypter and let it run?
- Aldous Huxley -
If it's a PAL DVD and you are viewing on a NTSC machine you will get a warning even if it's region free. If I'm wrong please correct me.
Yes, my Sony NTSC DVD player will not play any DVD's (even DVD's with no region code) if the video on the disk is PAL. It says it cannot play the disk.
Depends on the player. Some players actually do support PAL and NTSC, but most people never know it because of the region codes. Some NTSC players won't play PAL discs at all. You will not get a warning if your player supports both PAL and NTSC.
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 16:12 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 04:34 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 12:58 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 21:35
