I want a program that will capture for a preset amount of time and then convert to VCD format in one swoop. In other words, right now I have to capture a show for one hour, then come back and tell it to save a VCD compliant copy after it's captured. Is there a program that I can tell ahead of time to capture then save a copy for VCD so I can let it do it's thing while I sleep, then get up and quickly burn it?
Thanks!
Dazzle's MovieStar (comes with the DVCII) software does this. You can specify the duration of the capture and it will stop automatically when done. No need to convert if you capture directly to a VCD compatible MPEG. Then just start burning as soon as it is done capturing.
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
