  1. Hello all!
    I have a Leadtek Winfast TV2000 XP Expert card.It's not functioning right now and I"m trying to uninstall the PVR software that came with it.
    I'm unable to do so(when trying to uninstall,the uninstallation goes flawlessly and the computer asks for a reboot,afterwhich the software is still installed on the computer..... )
    Do you know what can I do,besides reinstalling Windows XP?
    Thank you in advance,
    Yohai.
    Sep 2003
    Is it causing a problem? And I assume you are talking about the PVR program and not the drivers.
  3. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Try booting into safe mode and uninstall. To get into safe mode press the f8 key when the system first boots.
    You can also use a registry cleaner to remove any signs of the software on the PC.
