How can I make a sample vob file from a dvd?
Is there any app I can use, a method or something?
- etuag -
Hello,
Try dvd decrypter or dvdshrink (dvdshrink can compress a dual layer disc down to 4.37gb for burning to a dvdr).
If you use dvd decrypter you can use chapter mode to select an individual chapter.
Dvd Shrink will let you select as much time as you want in reauthor mode
Well I know that..
But I just want to make a sample (a piece of the film) vob file ( 100MB size ).
What program, or method is the best way of doing that? -
Originally Posted by yoda313There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
if the VOB is already decrypted, then you could just use the "Merge & Cut" of TMPGEnc MPEG Tools. If not then you'll have to first grab a single VOB with DVD Decrypter.
Software to make sample of movie
By cyberlion in forum EditingReplies: 5Last Post: 7th Aug 2010, 06:32 -
How to make a karaoke VOB file from 2 (one audio and one text)?
By coxanhvn in forum Newbie / General discussionsReplies: 0Last Post: 5th Jul 2010, 00:57 -
Make a DVD from VOB files
By jmsrickland in forum Newbie / General discussionsReplies: 5Last Post: 6th Aug 2008, 19:30 -
Editing vob to make new DVD
By saramalik in forum EditingReplies: 5Last Post: 12th May 2008, 22:27 -
How to make a sample of an AVI file pls?
By incrediblej in forum EditingReplies: 5Last Post: 20th Dec 2007, 07:59
