How can I make a DVD with DVDStudioPro3 from a DivX movie? Has anyone for example written a tutorial for that?
all I can say is in my few attempts of doing so:
One, make sure you have all up to date codecs
of divx (v.5.2) and 3ivxd4.51 installed in your QT
Plugins folder.
Two, get the DIVX movie over to QT movie format,
with QT spec audio.
Third, take the QT movie, and run through Compressor 1.2
Four, author as you would normally in DVDSP3."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I used the DivxDoctor and made a .mov out of the avi file. Now I'm running it through the Compressor 1.2 with "MPEG-1 DVD" preset.
I know it would have been wise to run it with mpeg2 decoder, but all the "MPEG-2" presets have a time "limit" and the movie is over 2 hours (for example the longest mpeg-2 preset is "MPEG-2 120min...)
Is this going to have a happy ending? Should I use the MPEG-2 presets instead? -
Well, the MPEG1 will be much smaller in size, and lousier in quality, than the MPEG2. And, in my experience, it will take at least four times longer to encode using Compressor's MPEG1 encoder. You can make your own presets using whatever values that float your boat. My advice would be to abort the MPEG1.
If you're not ready to construct your own presets, why don't you just open the movie in the QT Player and export to MPEG2 from there? The interface is much simpler and it uses the same encoder as Compressor. Just remember that the built-in size gauge is assuming PCM audio. In other words, if you're going to be using AC3 audio, set the size about 600MBs larger than the built-in gauge indicates 8)
Vegas Movie Studio Platinum Pro Pack vs Adobe Premiere Elements 8
By bowmah in forum EditingReplies: 6Last Post: 27th Jan 2010, 21:15 -
Vegas Movie Studio 9 Platinum Pro Pack question
By dbanimal in forum EditingReplies: 8Last Post: 8th Jan 2010, 11:13 -
By wingspar in forum EditingReplies: 20Last Post: 7th Jan 2010, 17:50 -
Vegas Pro and Movie Studio Platinum 9 bug (confirmed with Sony).
By The village idiot in forum EditingReplies: 7Last Post: 18th Dec 2009, 16:21 -
Is Corel VideoStudio Pro X2 really worse than Vegas Movie Studio 9 ?!?
By vantechmag in forum EditingReplies: 2Last Post: 11th May 2009, 13:03
