Qutie strange. I have a Divx that the audio is off by just a bit when I run it in Dr. Divx but not when I use PowerDVD to view it. I have recently tried to convert and author it but I get the audio sync issue when I view the Video_TS file in PowerDVD, sam sync issue.
The process I am using is
1) VirtualDubMod 1.5 to extract AC3 audio
2) VirtualDubMod 1.5 to extract avi video
3) AC3Fix to fix extracted AC3 audio
4) Bitrate Calculator to calculate average bitrate (6008 Kbit/s)
5) TMPGEnc to encode the video only (2 pass VBR)
6) TMPGEnc DVD Author to create DVD files
7) PowerDVD to view Video_TS folder (audio sync issues)
8.) TMPGEnc DVD Author to write DVD (as soon as I get audio resolved)
[b] More specifics here
Video Specs (YAAI)
AVI Information
Filename:
Filesize: 734277632 Bytes (700.26 MB)
Streams (i.e. Video, Audio): 2
Video Stream
Compression: divx - DivX
Avg. Bitrate: 767.55 kbit/s
Resolution: 512x288
Color Depth: 24 bits
Running Time: 5867.08 s (1h 37m 47s)
Framerate: 25.0000 fps
Microseconds Per Frame: 40000 ms
Frames: 146677
Keyframes: 4177 (Every 35)
Audio Stream
Wave Type: 8192 - AC3 Audio
Avg. Bitrate: 224.00 kbit/s
Sample Rate: 48000 Hz
Bit Depth: 0 Bits
Channels: 2
Audio Delay: 0.00 s
Could it be a codec issue that I am facing here? I am a little stumped why it would play fine in PowerDVD in its orginal Divx format but not in Dr. Divx. As well why does this issue pop up again once I have encoded and authored it?
Any ideas?
Off the top of my mind what I think I will try
1) make a copy of the original avi
2) use YAAI to retard the audio
3) VirtualDubMod 1.5 to extract AC3 audio
4) VirtualDubMod 1.5 to extract avi video
5) AC3Fix to fix extracted AC3 audio
6) Select a small source range to encode
7) TMPGEnc DVD Author to create DVD files
8.) PowerDVD to view Video_TS folder and see how close I am
Weird issue with DVD to H.264
By reakt in forum DVD RippingReplies: 4Last Post: 24th Aug 2010, 18:15 -
Weird issue backing up DVDs
By downer in forum DVD RippingReplies: 6Last Post: 26th Aug 2008, 13:40 -
Very weird hard drive issue
By alegator in forum ComputerReplies: 3Last Post: 12th Jun 2008, 12:03 -
weird TV as a second monitor issue
By pheldd in forum Software PlayingReplies: 14Last Post: 6th Nov 2007, 04:48 -
Really, really weird issue with NEC 3550A
By ioannisds in forum DVD & Blu-ray WritersReplies: 2Last Post: 31st Jul 2007, 14:07
