Results 1 to 21 of 21
  1. Well I downloaded Swordfish off a ftp, and the ftp is all vcd's, and i downloaded it as 2 files only, both were mpg so i assumed it was vcd ready. burned it on nero, threw it in my apex ad-500a dvd player, it saw the cd, it told me the cd was the correct lenght, so i about pee'd my pants cuz the damn thing actually worked. But i pee'd to soon, because it would not play. it would sit there in the blue screen. I tried switching all the modes and stuff, no work. So right now im converting it to a vcd which takes about 8 hours. my question is, how do i see if i need to burn or convert first, and there has to be a better way to convert?
    plz help...thx.
  2. I dont know if your advanced at this stuff but here are some questions (and dont get mad if they are simple to know)
    1. did u use "create vcd" (wizerd)
    2. are they about 300mb (I have the movie) or are the about 116-118mb (if so they are avi, need to encode)
    3. do they work on the computer (if not download somwhere else, i suggust KaZaA at http://www.download.com , downloads fast if u have a brodband connection mine downloads at like 100k/bs to 210k/bs freeking fast!!
    I hope i have been of some help
  3. i wont get mad, there is lots of newbies out there. but no, the files are 497megs and 457 megs, mpg files, off a vcd ftp...they work on my computer perfectly
  4. try using vcdimager instead to make bin/cue then burn
  5. can someone tell me what site or FTP to go on to download movie? THANX
  6. hi, im josh can u please tell me how i can get swordfish.mpg? like were did you get it from e mail me at joshuaadams2001@hotmail.com i would really like it. if there is no way i can find it maybe you can mail it to me on cd-r and i could send you fast and the furious or exit wounds
  7. i just downloaed it in mpgs, never was in bins.
    Dec 2000
    Some airport, somewhere..
    Did you actually check if it was standard VCD compliant? Anything can play on your computer.
  9. Forget FTP's, ratios suck. AOL is the best. Quick and easy, who could ask for anything more? Infinite is very nice.
    Let me tell you a little bit about our Extended Warranty...
    ~Circuit City Video Sales 101~
  10. how do i check that? i got the mpeg properties, but iddnt undersstand how it told you if it was good or not
  11. I had the same problem with hannibul would not play ina apex 600a or a 660a only played in my GPX DV2000 and my pc I tried it a friend house who has a playstation with a VCd card and it work I do not know what kind of vcd they are that you download it might be 1.0 not 2.0 again i do not know
  12. um.......aol is the best?....ftp's suck?.....are you from mars?....thats gotta be the dumbest thing ive heard in all my life......aol is slow and has file size limits...12-14 meg.....ftp is as fast as the host and has no size limit.....requesting deadmails from a aol server is not good you ****...and not all ftp are ratio'd...maybe for you because you are a leech with no hookups....get a life man....and delete that aol......go on irc or a ftp...
    amazing......
  13. Well, if you dont have a leech or dump, then yes AOL is the best. For those of us non-cool people without the "hook-ups" AOL is much better. Do you really think that everyone here has the "hook-ups"? What do you suggest to them? I believe they would have a lot of fun with AOL. "Get a life" well, sorry, see, thats the problem, I do have a life and not on the computer all the time so I dont know about the "hook-ups", so, I do have a life, you ****. What was that?? What did I do to you? Issuses you have man. Getting mad over the computer, that is one of the dumbest things I have ever seen. Since you are so enlightened and have been graced with knowledge about FTP's and I am guessing 0-day sites, why dont you help out everyone else?
    All of you people without the rad-ass "hook-ups" like plg-tae, AOL is very easy to get stuff.
    No, I am from Bakersfield Cali, not Mars. Dude, be nice.
  14. aight can yall help me with my problem. i download movies from an dual oc3 ftp, that can do several megabits. so aol can lick me.
    whats the differnt between vcd 1 and vcd 2
  15. What do you mean by vcd 1 and vcd 2? Do you mean mpeg1 and mpeg2 or a two part vcd?
    Jun 2001
    bartlett,IL
    If anyone out there knows anything about ftp I need some advice. I'm trying to FTP some files from my mac to my PC. Is there a file size limit to FTP? Anything over 2.1 won't transfer properly. Or is that a file size limit of Win 2k?
  17. blips this isnt a ftp forum you idiot. now shut up. for god sakes. ya tho, mpg1 / mpg 2...there is a vcd 1 and vcd 2. anyways, ive done millions of test, my dvd player will NOT play anything, everything is in like 1" blocks and not even the righg color...and i dont think anyone here knows how to help me
  18. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Donwload this program http://www.vcdhelp.com/MPEGSequenceMakerv02.zip
    Open it up click on the 3 dots to browse for your mpeg, choose all instead of mpeg1 video only stream. You might get an error in German, click ok, it's telling you that it isn't a mpeg video only stream.
    Click on show options
    then post what it says in these fields
    Video Size:
    Aspect Ratio:
    Frame Rate:
    Bit Rate:
    Minum VBV Buffer Size:
    Constrained: (checked or unchecked)
  19. video size = 352*288
    aspect ratio = 0.9157 (ccir601, 625 lines, PAL)
    frame rate = 25
    bit rate = 1152000
    minum VBV buffer size = 40960
    constrained it checked.
  20. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    I emailed you too bladefist, but thought it might help if someone else came across the same problem:
    Your clip is a PAL clip. You said you have an APEX500 ad right? or at least an apex 500a. any way,
    Turn on your DVD player with out a disc in it.
    Press the setup key, go to general setup,
    in that menu there should be an option for TV type,
    arrow to it, and select NTSC, press play,
    then exit setup by pressing setup again.
    Your PAL VCD's should play now.
    The spec's are correct for a complaint VCD.
    Let me know if this works or not.
  21. yes, and again, this did not work
