I have a question.
Say I have my old PAL 8mm camcorder and just bought new NTSC Mini DV camcorder with analog In.
Is it possible to transfer my tapes from 8mm camcorder through new MiniDV camcorder straight to the computer??
Thanks a lot
Richard
If the camcorder has passthrough and DV out, just use a Firewire card and it should be no problem.
EDIT: Sorry, I missed the PAL part the first time. Now I'm not sure if the NTSC system would accept the video. -
Simply try and see.
All of my attempts to record NTSC source onto my PAL camcorder have failed, even when the signal has been converted to PAL prior to going to the camcorder. -
Originally Posted by mikesbytes
Also, Ribac, I think you'll find that you will encounter a similar problem I'm afraid...
I just need my 8mm tapes (from older PAL Analog camera) transfer through NTSC MiniDV camcorder straight to computer.So I would use MiniDV as capture device only.
Ribac, as Merkin is pointing out, most of the consumer equipment out there doesn't actually fully convert the signal.
It seems you have very little chance of cheaply getting the PAL signal thru your NTSC camera.
Perhaps your solition is a PAL compatable analog capture card/device. Then either convert to NTSC in the computer and out to DV, or convert to (S)VCD or DVD.
Don't buy the product unless the salesman can show it actually working with your PAL camera.
capturing minidv tapes
By zoranb in forum MacReplies: 62Last Post: 9th Feb 2014, 05:07 -
Capturing old tapes to PC - devices and software
By Writech in forum Newbie / General discussionsReplies: 6Last Post: 12th Mar 2010, 15:06 -
Capturing VHS tapes on pc
By BeachNut in forum Video ConversionReplies: 3Last Post: 12th Jul 2008, 22:08 -
Capturing Video 8-tapes
By Mållgan in forum Capturing and VCRReplies: 7Last Post: 26th Apr 2008, 03:07 -
Capturing VHS Tapes...
By soneman in forum Capturing and VCRReplies: 31Last Post: 15th Jun 2007, 15:08
