Is there anypoint to run CCE SP without using dvd-rb?
If so, how do I operate CCE alone?
It seems as if the quality of the film is not as good as it should be with DVD-RB.
Thanks for any help!
RTFM
it works very well alone -- most apps made to go with it are for the demo version only"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
someone can correct me if i'm wrong. to use CCE on it's own with a dual layer dvd you would have to use DVD2AVI first then use CCE to create a MPEG file, then you'll need to use a dvd authoring program before burning it to a disc. look at the guides to the left on using CCE.
the newest version has a lot more ability than before ..
like it can even now add pulldown"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
And do IVTC....
Has anybody tried?? Is it better than using the Decomb??
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 21:14 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 13:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 15:41 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 20:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 21:13
