    Aug 2003
    Ocala,Fl
    Is there a way to convert cd to tape?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Audio cd or Video CD??????
    If it's audio cd just hook up a cd player to the audio input jack on the vcr. You will get the sound with a blank picture.
    If it's videocd/super videocd/divx/xvid you need to use a dvd player that supports that format and hook it up to the vcr inputs. or if your pc has a tv out you could hook that up with the soundcard and dub.
    Kevin
  3. I'm assuming that you mean you want to transfer a video file you have on CD to a video tape. This can be done if you have a video card on your computer that has a tv output. You can hook up to your vcr via composite cable and then record as you would from another vcr. If you have a DVD player that can play .avi/.mpg files, you can also hook that up to your vcr via composite cables and record that way.
