I have an HP Pavilion and it has usb (1.0 I think) and firewire. My question is how can I upgrade the usb to usb2.0?
Results 1 to 9 of 9
What We Do In Life, Echoes In Eternity....
Originally Posted by bazooka
Yessir!
But be careful where you buy it, Dawg. It's real easy to run into Circuit City, Best Buy, or the like, and pay anywhere from 30-50 bucks. You should be able to find one online for $10-$15. -
Sometimes a BIOS update may carry USB 2.0 if the hardware was implemented but first revisions of the BIOS didn't support it. My Dell required a BIOS update in order to allow access to USB 2.0 speeds. I'm guessing this is pretty rare now so likely your best bet is a good USB 2.0 PCI card like an Adaptec. If you don't have FireWire I suggest their combo USB 2.0 and FireWire card. Doesn't cost much more and it'll save you another PCI slot down the road if you ever decide to get 1394.
FB-DIMM are the real cause of global warming -
Originally Posted by handyguy
I am not familair with this PC, but you might consider getting a new MB. Most new MB support 2.0 and would have other features you would like. Obviously it would have to be compatible with your case, CPU and RAM. But there are alot of MBs out there for less than $50, so for $30 more than a PCI card you could have a better computer.
Originally Posted by zzyzzx
Most of the newer boards already have usb2.0.
So if you have a fairly new board, there is a very strong chance you already have 2.0.
wintv pvr usb2 in linux
By diablo in forum Capturing and VCRReplies: 0Last Post: 10th Sep 2011, 08:43 -
dvp5990, usb1.1 or usb2.0?
By twister6 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 22nd Feb 2009, 14:22 -
Can I up from USB to USB2?
By jollyjohn in forum ComputerReplies: 16Last Post: 30th Aug 2008, 09:05 -
Pioneer DV400vk, using a USB2 HD
By Tom35 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 27th Jan 2008, 15:44 -
usb2 mouse keeps frozen up after no using it over night
By deejay.2001 in forum ComputerReplies: 2Last Post: 13th Aug 2007, 17:42
