I am using DVD Shrink. First, I open the disc, then I click the backup icon and it saves the ripped image to a folder I specify. Normally, it would eject the original DVD and tell you to insert the blank and it finishes.
At the time I didn’t have any blanks so I just hit “cancel” and saved the ripped image to my hard drive. How do I resume the process and burn the image? I cannot seem to resume the process in DVD Shrink.
Don't know about the earlier versions, but I'm using 3.2.0.15 and if you click on 'File' there's an option to 'Open Disk Image'.
I have already done the open disk image, then what do I do?
If I click backup, it goes through the motions that it would when I put the original DVD in the drive and rip it to my hard drive. -
if you alreaady made a image on to your hd and it's a single layer dvd that you converted then just burn the image with DVD DECRYPTER.
if that image you created on your hd is a dual layer dvd then yes it will have to go through the DVD SHRINK process of compressing it to fit on a blank dvd. then the burning process will kick in with Nero Burn as long as you have Nero installed on your pc.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
DVD HDD with ghost image
By Belfour in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Apr 2009, 10:29 -
dvd shrink image playback
By easy9 in forum Software PlayingReplies: 2Last Post: 19th Nov 2007, 22:28 -
Opening DVD Shrink 3.2 causes VGA to go Blank
By ppurdue in forum ComputerReplies: 2Last Post: 9th Oct 2007, 23:51
