i was wondering if u guys can recommend a program to record tv shows to my hard disk in avi format.. i used showshifter which is quite good but the demo period ended. is there a similar program
i treid to use virtual dub and avi io but both gave the error shown on the linked gif file (i hope attaching works . first time trying it) i made sure my capture device is turned off and made sure all teh services are turned off but it still gives this error
I am currentlyusing life view suite that came with my packard bell tv card but it only records as mpeg1 or uncompressed avi abd also it does not have the timer control to tell the program "only record programs for 50 minutes after i start the recording"
any help is appriciated
thanks
Problems Capturing from Vidoenics MX-1
By John Duvall in forum Capturing and VCRReplies: 0Last Post: 15th Dec 2010, 07:04 -
Capturing problems
By dbrunton in forum Capturing and VCRReplies: 9Last Post: 27th May 2009, 13:09 -
Capturing footage-problems ...
By perik in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 7th Dec 2008, 17:11 -
Having problems capturing my 360 on my PC
By RR420 in forum Capturing and VCRReplies: 4Last Post: 23rd Feb 2008, 10:50 -
Sorry HV20 more capturing problems!
By rhodesy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 14th Jun 2007, 06:54
