Hi all
This may be a silly question but im using 2 pioneer 106s 4x and i have a load of movies on 8x media-R is there any way i can get these discs open using my 4x drives like to decrypt them so i can make copys of the movies.
basically i want to use my 4x drives to open 8x movies can it be done?
THANX TO ALL THAT HELP
Hello,
Decrypt????? If they're dvdr they don't have any enctryption on them. Just use normal disc copying procedures. It's already the size of a dvdr so just copy it to the harddrive.
u are failing to understand im using dvd-decrypter to take movies from disc and putting them onto harddrivr but with these 8x discs its saying wrong media inserted the movies work on stand alone dvd player but i want to copy the movie onto harddrive is there a firmware i can use for my 4x pioneer drives to read 8x discs
Hello,
Well you didn't mention that....
A firmware upgrade would probably be a good idea. The pioneer website should have one.
Have you tried dvdshrink yet??? It would just do a straight copy - no compression since it's already dvdr.
So what you are saying is you have some films that have been put onto 8X media and you wish to put them onto your h/d.
The speed of the disk should make no diffrence if you are copying to your hard drive. 106 is a duel format drive so it should handle both + & - format disks Ok.
Just put one of my 8x disk i have used to back up a film and it plays and copies OK in my 105....
Just use windows to copy files to your hard drive unless you are making a iso of them.Not bothered by small problems...
Spend a night alone with a mosquito -
The 8x is for writing. It has no bearing on reading. If you have issues reading it then its probably simply the media (dye....) is not very compatible with your drive. Try cleaning the lens.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
What program do I need to decrypt W.?
By dannyreeves1 in forum DVD RippingReplies: 21Last Post: 21st Apr 2009, 10:10 -
Decrypt BD+ w/o the help of anydvd
By stew181 in forum Blu-ray RippingReplies: 1Last Post: 18th Mar 2009, 08:33 -
Ratatoullies wont decrypt.
By clownboyz in forum DVD RippingReplies: 26Last Post: 18th Nov 2007, 13:51 -
can't decrypt Ratatouille!
By studpuppy in forum DVD RippingReplies: 1Last Post: 25th Oct 2007, 22:45 -
Does Nero decrypt when copying DVD?
By shun in forum DVD RippingReplies: 2Last Post: 2nd Sep 2007, 21:09
