i have found Audio DVD creator and an another one Music DVD creator...beside these 2 is there any other software that does the same thing ?
@BJ_M
sorry your wrong!
Mainly Surcode is a high qualitiy DTS/AC3 encoder which could be used to encode multi-channel material to DTS/AC3, alternatively it will produce DTS(AC3)-WAV files for CD Audio usage.
It wonīt create a DVD-Video containing audio track(s) of any kind plus a dummy video track like Audio DVD Creator.
The only point what is simular: you can create compatible DTS/AC3 streams for DVD-Video authoring - but you canīt feed em any MP3 directly
bye Daphy -
Hi,
You can follow this link to learn how to make only-audio + menus DVD:
https://www.videohelp.com/guides.php?guideid=539
Regards.
Paco -
Originally Posted by daphy
i guess i benefit in the fact that i use these products professionally and know what i am talking about most of the time ...
I AM right - surcode makes more than the product you must of looked at - thaye also make a full line of DVD-Audio products .. see here:
http://www.discwelder.com/
surcode and discwelder are the same company - and this is the home page for both products
http://www.minnetonkaaudio.com/"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
sorry, I still donīt agree:
DVD-Audio has definitivly nothing to do with Audio on a DVD-Video
compare the specifications!
Discwelder offers in the lowest case PCM 2.0 44.1 KHz music on DVD in so called AOB container.
The other program is intended to save music (with a dummy video stream) inside a VOB container inside the DVD-Video specifications.
One point I would agree with you :
discwelder also can import such projects from extewrnal authored VOBs and since the version 2.0 itīs also possible to mirror the DVD-Audio files (AOB) as AC3 for DVD-Video standart on folder 'video_ts'
bye Daphy -
oh you mean a fake dvd-audio disk -- the poor mans dvd-audio ...
since dvd-audio doesnt seem to have taken off - i guess any way is as good as any other .. be easy to make on one's own that type ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
yep thatīs what those programs do 8)i have found Audio DVD creator and an another one Music DVD creator...beside these 2 is there any other software that does the same thing ?
Movie Creation/Editing Software
By jtrousd in forum Newbie / General discussionsReplies: 0Last Post: 22nd Oct 2011, 23:12 -
Full motion menu creation software with templates?
By TVJunkieLI in forum Authoring (DVD)Replies: 2Last Post: 7th Apr 2011, 08:54 -
Wanting more info on video rendering and creation software
By spiralthinker in forum Newbie / General discussionsReplies: 6Last Post: 11th Jan 2011, 13:51 -
Which DVD Creation Software and How does my mate do this....?
By Gun in forum Authoring (DVD)Replies: 4Last Post: 7th Oct 2007, 08:08 -
Free DVD Creation Software that offers Long-play?
By andymc35 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jul 2007, 15:42
