  1. I have made a slideshow DVD using DVDLab. In fact I have 16 slideshows, and 2 menus with links to every slideshow.
    Everything goes perfectly when I have less than 16 slideshows.
    If I put only 15 slideshows in my project, the result of compilation is "Done". If I put 16 presentations in my project, at the end of compilation I receive the message "Aborted". Why?
    Is 15 the maximum number of slideshows on a DVD? Why can't put more slideshows?
    Thank you.
    Lorand SZEKELY
    Apr 2004
    Miskatonic U
    What version of DVD Lab ?
    Have you asked the same question over at the mediachance forums ?
    Read my blog here.
  3. I have DVDLab 1.4 and I don't asked the same question over the mediachance forums.
    You can specify another DVD authoring tool that will help me?
    Lorand SZEKELY
    Nov 2003
    Everywhere I want to be
    If you are going to really do slideshows, you should probably use a dedicated program to create a "movie" for you.
    I use DVDLab for authoring and love it. But, I create slideshows in ProShow Gold first.
    Eric
  5. OK, I made some slideshows using Nero Vision Express 2, and for each slideshow Nero makes one .VOB file. Each slideshow is a Title and each image is a Chapter (in the DVD structure). So I have 16 Titles, with 60-70 Chapters each.
    I don't like menus made by NeroVision Express, so I went in DVD Lab to make my own menu. In DVD Lab I imported the .VOB files made by Nero Vision and added them like movie in the project. The problem is that I lose the original chapters in slideshows. I get 16 Titles with 1 Chapter each. What can I do? I need that chapters to navigate through images.
    My questions:
    1. Can I make in DVD Lab only the menu with links to each VOB file, and the original VOB file remain unchanged?
    2. If I author an entire SlideShow DVD with Nero Vision, can I use some programs to change the menu? I want to create my own menu, but I want also the VOB files to remain unchanged.
    Thanks again
    Lorand SZEKELY
