I want to apply a second soundtrack (german) to a NTSC movie.
The Movie (Avanti!) ist exactly 2:24:08 long. After demuxing with VobEdit, I got some strange results:
- the audio (AC3) ist 2:24:08 long
- the video is 2:00:00 long
Using Vdub-mpeg Mod, I can see, the video is 720x480 @ 30fps, but the audio is 25fps. Playing Video+ audio (after converting to .wav), audio is completely out of sync (as expected).Changing the video's framerate to 25fps doesn't work eitherync is better, but not really good.
Question: how can a 30fps NTSC video end up as a 25fps video?
23.997 I could understand, but not 25fps.
Results 1 to 9 of 9
I don't understand 'hybrid' here (PAL/NTSC mix?). And VFR? Is that possible? Only thing I forgot: it uses progressive frames.Originally Posted by nufan292
The short answer to your original question is - it can't. If it is NTSC, then the framerate must be either 23.97 or 29.97. To me, this means something has gone awry with the demux. Either ifoedit screwed the pooch, or something got chopped.
Is the audio a constant time frame out of sync, or does it drift further out as time goes on ?
Have you listened to the end to make sure the last (or indeed, first) 24 minutes aren't missing ?Read my blog here.
I demuxed with VobEdit, BeSweet and DVD2AVI:audio is always the same.
I looked at demuxed video output from VobEdit/DVDDeCrypter and DVD2AVI: all the same:VDub says:30fps but only 2:00:00 length.
I had a look with DVDPatcher and it states:NTSC 720x480 @ 30fps
BeSweet says:AC3 Audio @ 25fps as HeadAC3 says the same.
For me it looks like, the audio was done at 25 fps and the Video at 30fps and muxed at 25fps .
The Audio file is complete, nothing missing and nothing added.The sync drifts away with the time.(i.e the video is faster than the audio)
But: I used tmpgenc to cut the first 10 Minutes of the video and used CoolEdit Pro to save the first 10 Min of the new audio.After converting the 10 Min audio to AC3 and remuxing, the audio is in sync. That's stranger than anything.
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 10:05 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 18:57 -
Wrong resolution/framerate on mkv converted to bluray with TsMuxer
By tomamitai in forum Video ConversionReplies: 2Last Post: 30th Mar 2009, 04:13 -
i need a framerate converter
By snafubaby in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2008, 22:44 -
Framerate Conversion
By rackball in forum Video ConversionReplies: 10Last Post: 11th Aug 2008, 05:04
