Can anyone help with reference to a post or a sticky on making a (simple) highlight DVD just from ripped vob files out of my favourite DVDs. Would this be an easy process?
The reason is whenever someone calls in and wants to see my home cinema it would be a lot easier than swapping discs around, I would love a demo disc like the ones they have in retail outlets,
Give it a try and let us know
You probably want to use DVD2OneX's join functions to join up chapters you've ripped. However I doubt it will be totally straightforward, for starters not all DVDs use the same audio format. I also seem to recall that the join mode is quite fussy, especially about joining two clips that arent in identical formats.
Rip Your VOBs first, then use them as input on Chapters menu in old Sizzle to author them...
I have done this with Toast 6. Just drag them and burn them under the video tab. If you have Toast with Jam, it includes the AC3/Dolby encoder, so it will just "pass-thru" both the video and the audio. This is nice since it does not reencode the video, it simply prepares it and burns to disc.
One caveat: there seems to be a bug in Toast that the first video in the order will play last: therefore put your last song at the top of the list and your first second in the list and all will be well. If you want menus, just click the 'add menu button' checkbox.
If you want the AC3 to be passed thru, make sure you have Dolby Digital selected (requires Toast with Jam). -
Vaj, I'm pretty certain that Toast passes through an existing AC3 audio track without re-encoding it. Jam is only needed if you want tracks encoded to AC3 or if you want to use the DVD Music Album feature in Toast.
Subpicture highlights look jagged on TV
By Henkie in forum Authoring (DVD)Replies: 9Last Post: 10th Feb 2014, 14:08 -
Football Highlights - Video Novice
By libertyboy03 in forum Video ConversionReplies: 3Last Post: 23rd Sep 2011, 20:06 -
GfD button highlights
By bratpop in forum Authoring (DVD)Replies: 1Last Post: 3rd Jan 2008, 07:38 -
Creating highlights for buttons in Encore
By newsphotog in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 19:19 -
Blown-out highlights -- can I make them less annoying?
By grannyGeek in forum RestorationReplies: 13Last Post: 9th Jul 2007, 21:52
