hi i'm trying to convert a div3 avi movie file to svcd format but the audio gradually goes out of sync.i suspect is the fps problem and after using gspot to check the output, there is a problem.
The source avi fps is 23.976 and i used tmpgenc's ntsc-film selection to encode into svcd but it always give me 29.970fps output.. Other than that i also used the extracted audio wave file using goldwave when encoding. Is there anyway to correct this probelm? thanks in advanced.
About the only thing you can do is stretch or shrink the audio to get it back in sync,i had this problem with one divx3 clip and by the time it got to the end it was 17 seconds out of sync but stretching it fixed it.Use goldwave to stretch or shrink the audio as needed.Tmpgenc's ntsc-film selection is the correct one for 23.976,it encodes at 23.976 and applies 3:2 pulldown so it will play at 29.97 fps which is needed for svcd playback in a dvd player.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
AutoGK, Audio Sync problem.
By steve_hawthorn in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2009, 00:39 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26
