Results 1 to 17 of 17
  1. How long does it take to rip and transcode a dvd?
  2. Member BrainStorm69's Avatar
    Aug 2002
    Texas, USA
    It depends on how fast a DVD rom drive you have and how fast your processor is. Probably no more than an hour, and could be quite a bit less.
  3. Shrinking (on, say, an apple g3 500MHz processor)
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    27 minutes, 55 seconds, 112 milliseconds
    Ripping depends primarily on your DVD-ROM and the speed and configuration of your hard drive(s).
    Secondary factors include amount of RAM, the complexity of encryption on the DVD, how fragged your hard drive is, CPU, and I'm sure there are many more.
    Transcoding is much the same, although the CPU has a greater influence on the fluctuation of transcoding speeds than any other factor.
    If in doubt, Google it.
  5. But would it be realistic for a single computer to take days to do it? Surely the iBook G3 can work faster than that?
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Within a couple of hours I would say.
    Apr 2004
    Miskatonic U
    Even a slow PC would do it in no more than a few hours. Re-encoding (as opposed to transcoding) might take up to 24 hours on a slow machine if set to VBR with 4 or more passes.
    What software are you using ?
    Read my blog here.
  8. Here's what I've got:
    Hardware:
    LaCie 250gb Firewire HD
    Pioneer DVR-108
    Software:
    DVD2ONEX
    Toast Lite
    Mac The RIpper
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'd PM a mod and get this moved to the MAC forum. There'll be people (did I say people because I meant hobbits ) that can help you.
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Do you rip the hard drive first, then transcode, then burn
    or
    transcode while ripping, then burn
    Read my blog here.
  11. rip, transcode, burn
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    DVD2One can't rip so I'd assume DVD2OneX is the same.
  13. WHat are you talking about Jimmy? DVD2ONEX is a transcoder....
  14. Nevermind, brothers. I think I got it under control. Thank you and good night. And remember....
    Vote Kerry '04...
  15. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    DVDShrink is a transcoder, but it can rip also. DVD2One is just a transcoder. nothing more. That is why it's kinda funny that DVDShrink is free, yet you have to pay for DVD2One
  16. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'd go easy on the political statemnts if I were you ...
