I am moving up to a digital video camera and need a firewire port in my PC. I see several for under $100, and then there are cards like the Canopus DV Storm for over $1000. I understand there is software differences, but what are the hardware differences? If all I want to do is capture video (analog or DV) to my PC for the purpose of editing it and converting to MPEG2 (DVD or SVCD burning), what can these high-end cards do for me?
THanks,
Robert
1. Real time stuff
2. analog/digital capture capability
3. Better codecs (hw based)
4. software bundle (you're aware of this already).
...and maybe some more that I'm not aware of.
quite frankly, typical 'hobbyist' can live with cards on the cheaper end of the scale. It just depends on how serious you're into this thing, and maybe how much money you're willing to spend. If you're thinking of making money from this, then you should probably go to the higher end.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
