I installed powerVCR and was getting ready to capture following one of the guides from this site. The problem is that PowerVCR wont start. It says "Application has encountered a problem a needs to close". I even tried a new OS install, all clean w/ no other APPS installed, latest nvidia drivers and WDM drivers. No help. Same problem.
I am running XP w/SP2 and my card is an MSI FX5900 w/VIVO.
If powerVCR does not work, whats the second best option to capture directly to mpeg?
Or should I pursue capturing to AVI w/ virtualdub and then convert to mpeg with what?
I am not planning on editing thats why I was trying to capture to mpeg directly.
thanks for the help
Results 1 to 1 of 1
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Powervcr II 3.0 Deluxe
By vijaye05 in forum Capturing and VCRReplies: 1Last Post: 7th Oct 2008, 04:30 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
