hello need some advice/help,,have the full version of svcd2dvd and have tried converting two different svcd and the program just hangs and stops , no error message or anything.Got the first one to encode to dvd by ripping the mpg with isobuster,burnt it to dvd ,works great.Have tried everything with the second svcd and no luck.Any help gratefully recieved,,hers the log thingy Starting SVCD2DVD: v1.51.2.0
Begin time: 15:21:35
******** Ripping BIN images to get mpegs (VCDGear -fix)
VCDGear 1.76 final build 031225 coded by Dracore (vcdgear@hotmail.com)
Testing and quality control by MACKerMD
Language: English
Version: 3.50 - Jan. 1, 2003
Translation by: Dracore
processing method :: (bin2mpg)
.bin src(In) -> C:\Documents and Settings\gary\My Documents\vcd2dvd\DVT_AlfieMOViEA.bin
.mpg dest(Out) -> C:\Documents and Settings\gary\My Documents\vcd2dvd\DVT_AlfieMOViEA.mpg
Fix MPEG Errors
[DVT_AlfieMOViEA.bin] Detected sector size: 2352
# 0%
#searching...
Track 1: 545261528 bytes [08:26:64]
#searching...
1 track(s).
Setting read size to: 2352
Setting write size to: 2324
# Track 1 -> writing...
# 0%
# 0 MPEG block correction(s) applied
# 2 Blocks padded
# OK!
(Total size: 1062MB, Duration: 00:02:29, Rate(MB/Min): 426.67)
Analysing File: C:\Documents and Settings\gary\My Documents\vcd2dvd\DVT_AlfieMOViEA.mpg
++ WARN: packet length beyond buffer (pos = 18 + size = 2306 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
-->Processing 1 mpeg files
############### New MPEG File ###############
Type: VCD
Horizontal Res: 352
Standard: PAL
Audio SampleRate: 44100
******** Demultipexing original mpg file
(Total size: 520MB, Duration: 00:03:28, Rate(MB/Min): 149.49)
******** Resampling audio from 44.1 KHz to 48 KHz
(Total size: 82MB, Duration: 01:31:33, Rate(MB/Min): 0.90)
******** Trimming start of video ES
System.IO.FileNotFoundException: Could not find file "C:\Documents and Settings\gary\My Documents\vcd2dvd\DVT_AlfieMOViEA_DVD.mpv".
File name: "C:\Documents and Settings\gary\My Documents\vcd2dvd\DVT_AlfieMOViEA_DVD.mpv"
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
at System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize)
at System.IO.StreamReader..ctor(String path)
at _S_VCD2DVDMPG.210ff09a2516b1a7.54d310f1b21a8a6d(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5() thanks
Try the other demuxer in the options.
Megui encoding stops
By sanosuke in forum Video ConversionReplies: 1Last Post: 20th Dec 2012, 22:36 -
MKV stops
By kcmccombs in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2011, 23:17 -
XP chkdsk stops at 56% on stage 4 of 5...
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 17th Jul 2009, 01:11 -
Burning Stops at about 23% ?
By dagerousdave in forum DVD & Blu-ray WritersReplies: 8Last Post: 20th Aug 2007, 13:29 -
ConvertXtoDvd stops converting:( HELP!
By BlackRose in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2007, 18:05
