what program will allow me to save a slideshow of still pictures, so that i can use it in tmpgc and then on to dvd authour, or another way of asking what type of file do i need for a slideshow of stills so that it will got into tmpgnc![]()
many ways to skin that cat (so to speak)..some editors do that...also, I have used memories on tv to create a decent slide show then instead of authoring it w/ their tools, taking it's mpeg output and pulling that into other authoring tool...(use options to select save streams and other option not to burn your result).
you can download a demo from their site (watermark I think)...it should be able to use the tmpgenc encoding but maybe not for the demo - download the mpeg2 plugin as well (which if you have the extra $15 works well if you buy the package)..."As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole." -
You might also try Slide Show Movie Maker. It will create an AVI of your pics, which can then be imported into TMPGEnc for conversion.
Best of all, it's FREE!!!just a thought
mastersmurfie
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 04:18 -
Creating flash/mpg/etc slideshow with text from file
By RandallM in forum Newbie / General discussionsReplies: 0Last Post: 12th Nov 2010, 13:50 -
My DVD slideshow GUI project file has disappeared.
By sjonas in forum Newbie / General discussionsReplies: 7Last Post: 19th Oct 2009, 13:35 -
Creating a slideshow as a standalone .swf file
By marioval in forum Newbie / General discussionsReplies: 8Last Post: 2nd Sep 2009, 12:36 -
dvd slideshow corrupt mpg file
By davol in forum Newbie / General discussionsReplies: 5Last Post: 11th Dec 2007, 06:35
