As title please-tried one that i was given.
Open drawer, press set up on remote, press vol + and vol - three times until ver 255 comes up on top rhs,
Still using the remote scroll until 4001 comes up and change it to 4000.
THE PROBLEM IS I CANNOT FIND 4001/4000!!!
What i get is-ver 255, 3001/3000 and ver 1 to 6 and nothing else.
Im going mad!!
Help please.
Thanks,
Simon
yuor post does not help you are not tell us what is going and what you are trying to copy.
Sounds like you got the wrong model number for those instructions to disable macrovision with your remote control thru the menu,maybe someone else here has the same model that can verify or help you more.
I am trying to copy a dvd-to my Liteon 5006 dvd recorder.
My dvd recorder tells me the disc is copyrighted and will not allow me to record.
I asume that if i disable the macrovision it will allow me to do so?
Regards,
Simon
Maidston MD-BR-2102 firmware needed
By newgen2005 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th Jul 2010, 14:33 -
How to disable a DVD button?
By dexter30 in forum Authoring (DVD)Replies: 2Last Post: 23rd Feb 2010, 18:27 -
How to disable macrovision in Go Video DV1140
By wbsearch in forum Newbie / General discussionsReplies: 11Last Post: 17th Nov 2009, 23:10 -
Philips DVD player DVP5990K - is there a way to disable HDCP?
By ademarfj in forum Newbie / General discussionsReplies: 6Last Post: 30th May 2009, 23:32 -
Cannot disable DVD subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 8th Aug 2007, 17:56
