Results 1 to 9 of 9
  1. what are these ?
    I got them alongwith the .avi format.
    I can play the .avi on my DIVX player , but what to do with these 2 file extensions. Do I burn them as-it-is with that '.avi' file[ in all making it 3 files on the same disc ] ?
    TIA
    install vobsub.
    or do you have a standalone divx player?
  3. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    those are subtitles if you don't need subtitles then you may not include them in the burning
    hacking the Net using typewriter :D
  4. Thx. all
    yes, I have a standalone divx player.
    so I was thinking that it will catch those subtitles too while going for the .avi file.
  5. Guyz
    I'not sure if I still got it ....
    since I want to play the avi + sub on a standalone divx player, can I just burn the '.' files as-they-are on the disc ?
    mucho thanks for any help
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    it depends if your divx player supports .sub/.idx. Check the manual. Some players supports srt text subtitles, you can convert .sub/.idx to srt with vobsub or subrip or download srt subs from www.extratitles.to .
  7. Coool.
    I just checked and my player supports "SRT Untertiteln " ....so I guess I know now where to go from here.
    Mucho Thx.
  8. I have an avi that has subtitles in the with the extensions .sub and .idx (and a 3rd .sfv). I have no idea what I am doing. I can make the computer burn a DVD, but want the subtitles to go along on the DVD as well so I can watch it on my DVD player. Any ideas?
    I am using Nero.
    P.S. I am totally new to all of this. I think that the subs may be "forced subtitles" as they are on The Passion of the Christ. (haven't seen it yet)
  9. Howdy....
    I don't think I would be of much help here.
    I tried to burn the subs alongwith the avi and running the thing on my divx player just plays the avi [so what's new ] and there's no subs..
    [ eventhough the subs are there on the disc ]
    so I gave up....and contain myself with just the 'english' knowledge I have in my head :P
