Hello all, not sure if this is the right forum or not but here goes:
I hate how slow the MainConcept encoder is in Vegas 5.0, it's really frustrating, and I know CCE is a heck of a lot faster, well worth the investment. BUT, is there a way that I can encode from Vegas to CCE FROM THE TIMELINE IN VEGAS, i.e. not encoding to AVI first. Someone has said some stuff about frameserving but I tried it and it seems to go painfully slowER than just using the mainconcept.
Bottomline, is there a way to get the speed of the CCE encoder via encoding from the Vegas timeline?
Mike
Results 1 to 9 of 9
Yeah. Use the debugmode avi frameserver
Works great
http://www.debugmode.com/frameserver/ -
wow that was a quick reply! Unfortunately - that's the one I used, by the Satish guy or whatever his name is, I must be missing something if it "works great" -anything I need to know b4 using it, settings or what not?
what I usually do is go to File > Render As > PluginPac Frameserver .AVI
then open up CCE while Vegas is still running and load the AVI as your source file
if you have an old one installed there is an updated version for vegas 5 i think
do you get some sort of error message somewhere along the way? -
no, I don't think so, let me mess with it a lil and see what happens again, nice picture, I put mine too, didn't know we could do that hehe
what about the part that says "please select/check the following options before starting to frameserve" ?
RGB24, RGB32, YUY2 ??
Which do I pick? I'm using footage captured from a DVC80 camera, making instructional DVDs here.. -
hmm... I can't remember it asking me that question before but if it's just frameserving you can go with RGB32 for the most color information
Maybe I'm using a newer version, because it does ask which,, someone told me than an older version of CCE is better, is that true, can I buy an older version haha
you know what i noticed about CCE, it doesn't have all the options and stuff that the Vegas encoder does. I use DVDworkshop 2 for my dvd authoring and apparently CCE does "lower field first", and the default in Vegas is "upper field first" - does this matter? I would think it doesn't
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 19:57 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 17:12 -
colors shift when frameserving from Vegas
By crisciunas in forum Video ConversionReplies: 7Last Post: 16th Oct 2009, 16:24 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 21:31
