I've got a few short video projects I've been trying to put on a DVD. The structure is basically two main features on the main menu, and a link to a special features menu, with a few short clips on that page.
I have a 3 year old copy of the watered down MyDVD, which seems to work, but I haven't spent too much time with it for this project because I figured there had to be a better program out by now (if that was ever even a good program). I've been trying to use Nero Vison Express (??). But it keeps crashing on my Pentium 1.8, with 512k memory, and running Windows Me. I downloaded the new release from 10/25, and it seems to be crashing less, but it doesn't seem to support a more complex DVD design. That is, I can't figure out how to get a second menu layer (among other things).
Can anyone offer any suggestions for a software that may help? I hate to spend a lot of time hacking through a project, if I am beat from the start because of the program.
One last thing, I am encoding from Premier's .avi files, so the encoder built into the program should be able to encode in good quality.
Thanks!!! Andy
Tmpgenc DVD Author
DVD Lab (or DVD Lab Pro)
DVD Architect 2
will get you startedRead my blog here.
Yes dvdlab pro rocks i love it. It may seem complicated but it really isn't. I just fooled around with it for like a day and pretty much know it now. The menu options are amazing plus you have full control on how you design your dvd. Get it !! Plus it has a try for 30 day option.
DVD menu software to import into TMPGEnc Authoring Works 4
By mobie29 in forum Authoring (Blu-ray)Replies: 0Last Post: 28th May 2010, 13:34 -
Vista compatible disc authoring/burning software with sub menu options?
By wetcamelfood in forum Authoring (DVD)Replies: 7Last Post: 7th Jan 2009, 21:08 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
multi-VTS DVDAuthorGUI-like recommendations?
By ecc in forum Authoring (DVD)Replies: 1Last Post: 7th Mar 2008, 05:29 -
What software to create a multi-title menu?
By ChrisPappas in forum Authoring (DVD)Replies: 1Last Post: 26th Nov 2007, 02:28
