I have to capture my video in short segments to keep audio in sync. I capture then stop when there is a scene change. Since there is a little overlap of footage from one AVI to the next, I select my range in VDub then frameserver to the encoder. I then MERGE all MPG files together when done.
Is there a way to load all teh segmented AVI files and remove the overlapping portions then frameserve?
LS
After opening all the segments with VDub you can easily remove the sections you don't want.
http://www.doom9.org/capture/postprocessing_vdub.html
Read part 7.1.11 about cutting out commercials (bottom of the page). -
I took three avi files that had a few seconds of overlapped video sections. When I loaded the first then did a append with the next two, there were no overlaps anymore. Does VDub know when there is duplicate frames then merge them when loaded? I searched the video over and over and could not find any overlap. Very nice...Originally Posted by erratic
LS -
I used the DNR and HiQuality Smoother like the article suggested and I cannot find a spec of difference in the video. The file size was 1K larger then the unfiltered. I think the footage is clean enough to not need it.Originally Posted by erratic
Thanks!!
LS -
It looks like I have to revert back to the old meathod. If I load the avi file and append all the rest then encode the audio is just as far off as if I captured it all in one shot.Originally Posted by erratic
If I encode all the sections into multiple mpg files then merge them it's fine. What a pain but it works.
Thanks!
LS
Removing sections of audio.
By Ringwood in forum EditingReplies: 3Last Post: 8th Dec 2011, 08:28 -
Conan O'Brien mouth cutout interviews - help?
By menoseficaz in forum EditingReplies: 15Last Post: 3rd Apr 2011, 11:40 -
Cutting sections of HD files
By Fire Foxer in forum EditingReplies: 10Last Post: 29th Nov 2009, 12:21 -
Lots of problems that transcends different sections.
By guy_edwin in forum Newbie / General discussionsReplies: 4Last Post: 20th Dec 2008, 05:36 -
DVD to Mpg - Missing Sections
By Tyler2000 in forum DVD RippingReplies: 1Last Post: 11th Dec 2008, 13:29
