I recently tried converting some avi's i had sitting on my harddrive and set a batch encode up and set it to encode. The first two encoded fine but the rest seemed to just enocode the audio and no video was showing. Is this a codec problem, if so whats that best way to fix it?
Open each individually in your editor and make sure they're all compatible files. "AVI" doesn't really tell you anything about what format it is since it's just a container extension
If some need transcoding, do that to get all the same format files, then try again with the batch encode
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 21:28 -
Encoding Video
By manicjonah in forum Newbie / General discussionsReplies: 8Last Post: 20th May 2011, 12:41 -
will a separate video card speed up video encoding?
By edong in forum ComputerReplies: 12Last Post: 21st Oct 2009, 18:37 -
New to video encoding.
By pickledpacman in forum Video ConversionReplies: 1Last Post: 25th Mar 2009, 11:39 -
Best Video Encoding?
By mvtm in forum MacReplies: 3Last Post: 15th Mar 2009, 14:56
