I have winxp/sp2 installed, got the installation issued fixed but now am having problems running the program...
"SCVD2DVD.exe- application error The instruction at "0x110359e3" referenced at "0x000000000". the memory could not be "written"
thanks for the help
When does this happen? What did you do to fix the "installation issue"?
when i try to start svcd2dvd the error occurs. at first i had the installation issue ( sp2dep issue) the edit boot.ini did not help but when i add "msiexec.exe" to off in the "dep" setting it installed fine. After a reboot and install, when clicking on the SVCD2DVD icon it pops up with the application error. This is clean install i just did last week of winxpsp2.
have you added the svcd2dvd.exe to the DEP settings too?
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
error - cannot start capture
By hoader in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jan 2012, 20:53 -
error to start Windows Media Encoder
By George2 in forum ProgrammingReplies: 14Last Post: 21st May 2009, 00:31 -
CDCheck - same error repeated, seems to start in Adobe Encore
By moxiecat in forum Authoring (DVD)Replies: 1Last Post: 26th Dec 2008, 17:25 -
SVCD2DVD error on start up 'Application has generated an exception...'
By Turnstyle in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 16th May 2007, 04:53
