I have a problem with TMPGenc. When i want to convert AVI file (to DVD) with TMPGenc, it shows that that movie is 458 min 00 sec leghth (project wizard window 4/5). Maybe file is somehow corrupted? Please advice me, how can i setup TMPGenc to get best dvd-player compatible movie. Thank You in advance.
AVIcodec results
File : 701 MB (701 MB), duration: 1:42:14, type: AVI, 1 audio stream(s), quality: 39 %
Video : 639 MB, 874 Kbps, 25.0 fps, 512*288 (16:9), DIV3 = DivX v3MPEG-4 (Low-Motion), Supported
Audio : 62 MB, 85 Kbps, 48000 Hz, 1 channels, 0x55 = Lame MP3, Supported
It appears your avi contains VBR audio, TmpGenc doesn't like this. Use virtualdub to save out the audio as an uncompressed wav file (it will get much bigger). Use this wav file as the audio source in TmpGenc when you encode.Originally Posted by geivis
Thanx, i`ll try it (i`ve read about that earlier)
. Another question is: resolution 512x288 is 16:9, should i choose DVD PAL(16:9) or just DVD PAL? What aspect ratio and video type should i choose in expert settings for source section? Should i choose 2000 kbps video bitrate or left original 874 kbps (like AVIcodec shows)?
Yes, to DVD PAL (16:9).
The AVI bit rate is irrelevant when determining the DVD mpeg bit rate. "As high as possible" is what to use, with media size and video length (in time) as limiting factors. Use a bit rate calculator to find out what bit rate to use. (Leaving a few 100 MB safety margin, specially when doing VBR encodes.)
/Mats
Advice needed on best conversion to MPEG-2
By am_dew in forum Video ConversionReplies: 10Last Post: 7th Feb 2012, 11:37 -
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 08:46 -
TMPGEnc Plus converts AVI to MV2 instead of MPEG movie
By buzzsaw in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2009, 19:36 -
Mpeg 2 capture advice please
By joker2 in forum Capturing and VCRReplies: 3Last Post: 28th Jun 2007, 16:11 -
using virtualdub mpeg-2 for cropping and need advice
By mrgain in forum EditingReplies: 2Last Post: 10th Jun 2007, 11:59
