I'm having problems making a copy of a dvd in Toast 6.0.3. I have had only 1 successful attempt out of about 7.
I have a:
Machine Model: Power Mac G4
CPU Type: PowerPC G4 (3.2)
Number Of CPUs: 2
CPU Speed: 1.25 GHz
L2 Cache (per CPU): 256 KB
L3 Cache (per CPU): 1 MB
Memory: 1.25 GB
Bus Speed: 167 MHz
For the burner :
PIONEER DVD-RW DVR-105
and a:
TOSHIBA DVD-ROM SD-R1312
for the reader.
The disc (Aladdin) was originally ripped with MTR and then run through DVD2ONE. So I took the ripped DVD and tried to make a back-up of the back-up in Toast and about 3/4 the way through Toast freezes up. I then have to force quit Toast and restart my computer for the eject button to work.
The original ripped DVD plays perfect and has made 1 successful copy with Toast (with exactly the same steps used in all the attempts). So I have been trying to figure out how I can make this proccess more dependable (eventually the kid will scratch the back-up). Or is the best way just to save the VIDEO_TS folder from the ripped DVD to my hard drive and then make a DVD-ROM (UDF) disc in Toast? Just trying to cut out extra steps if possible.
Thanks.
I find it most reliable to not do a direct disc-to-disc backup, as read errors will make a coaster. I use Toast in Copy mode, set the read drive to the one the DVD I want to copy is in, then go to the File menu, and choose 'Save as Disk Image'. This will save it as a Toast disk image on my HD. I then put Toast in Disk Image mode, drag the image to Toast's window, insert a blank, and record. Perfect success so far...
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
I'm an idiot! How do I copy a DVD using Mac The Ripper and Toast 10?
By brido7760 in forum MacReplies: 2Last Post: 20th Jul 2009, 11:42 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
Making a copy with DVD santa
By 1234567 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jul 2008, 02:19 -
Can't Toast VIDEO_TS ( not copy protected)
By rotuts in forum MacReplies: 3Last Post: 21st Jun 2007, 14:28 -
Why can't I copy to DOUBLE LAYER DVDS using Toast 7.0.2?
By maccaneer in forum MacReplies: 3Last Post: 28th May 2007, 16:19
