I have made a lot of coasters and not one good disk. I have tried using DVD Decryptor then DVDShrink. I have also tried just DVDShrink. Both ways I am using Nero to burn the disks. I have a Sony DRU-510A burner and have an AMD 2700+ processor with 2 120 GB Hd in Raid 0, and 1024k of 400 mhz Ram. The problem is in the burning. Every disk gets an error at some point in the burning process. I have tried TDK 2x DVD-R, CompUSA 2x DVD-R, and I use Imation DVD+RW first to check to see if I copied good. Most of the time it seems that the Imation disks until I play them back. Usually towards the end of the movie, it hangs up. The others do the same thing at whatever point the error occured. I am following the steps given in the guides on this website. What is my problem?
Disable burning with Nero and burn with DVDDecrypter.
If in doubt, Google it. -
...also shrink a little bit more, like down to 4.2 GB to avoid the troublesome outer edge of the disc (cures "errors at end of movie" problems for unreliable media).
/Mats
Avi burning problems
By blitzen in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2011, 13:09 -
Dl burning problems
By calanda in forum DVD RippingReplies: 13Last Post: 14th Apr 2010, 00:25 -
TYG02 burning problems.
By videobread in forum MediaReplies: 2Last Post: 11th Oct 2009, 13:51 -
DVD burning problems
By Tbag in forum ComputerReplies: 13Last Post: 3rd Sep 2008, 16:55 -
DL problems after successful burning
By m-man in forum Authoring (DVD)Replies: 7Last Post: 9th Jul 2007, 20:53
