Results 1 to 10 of 10
  1. Using TMPG DVD Author 1.6 I get an error after I finish writing the files to the output folder. What happens is I click on create DVD and I get an error The ordinal 3001 could not be located in the dynamic link library px.dll. Any ideas to what I am missing or what has to be done?
  2. No ones seen this?
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Have you reinstalled TDA yet????? That's always the first place to start in my opinion.
    Also, check the manufacturer website for a faq list.
    Kevin
  4. I'm a little confused. I am not sure what TDA is but if you are referring to Tmpg DVD Author... Yes I have it installed but I get the error.
    I've checked the faq but unfortunately I can't seem to find anything on my particular issue.
    Nov 2001
    Upstate NY
    yoda means uninstall and reinstall Tmpg DVD Author
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    px.dll is in prassi , recordnow max , etc ....
    sounding like a buring app problem, maybe TDA uses the same burning engine ?
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    Originally Posted by JEEPn
    i was exactly right --
  8. Yeah I saw that and tried it with a reboot and still nothing. I would assume that by putting into TMPEenc folder they are referring to the DVD Author software and not the encoding software.
  9. The answer is...... DL the same version that you have from Pegasys-inc and install it. This will get you the right version of px.dll and it will place it in the appropriate places. Uninstall the software and px.dll as well as other dll's will remain. Then install the version of TDA and your rocking.
    Thanks for the help guys.
