Hi. I downloaded Media Player Classic (not Windows Media Player) here.
http://sourceforge.net/project/showfiles.php?group_id=82303&package_id=84358
I went to the Format configuration screen and found a selection for RealMedia files. Since I didn't want to install Realplayer, that was a nice option to have. But when I went to open a RAM file, it says it failed to render the file and that a codec for it was missing.Is it really possible to view RM files in MPC?
It has the Splitter/Source filter for RealMedia built in, but it doesn't have the codecs. You'll have to install RealAlternative for that.
Playing PGS subtitles with MPC.
By doctorm in forum SubtitleReplies: 2Last Post: 28th Jan 2012, 13:25 -
Playing DVDs in MPC-HC
By ayim in forum Newbie / General discussionsReplies: 1Last Post: 26th Dec 2010, 09:01 -
Playing mkv with MPC-HC doesn't work as it should
By ronlut in forum Software PlayingReplies: 7Last Post: 6th Jul 2010, 18:13 -
MPC not playing m2ts and ts files
By krohm in forum Software PlayingReplies: 36Last Post: 25th Aug 2009, 08:43 -
Particular AVI not playing in MPC
By the_shyguy in forum Software PlayingReplies: 8Last Post: 7th Jan 2009, 06:22
