i am making a slideshow and putting it on dvd. what i want to do is have text animations (like blinking or flipping around) and text transitions (like dissolve or fade in). is there a good program for this. right now i have ulead videostudio 8 and i can add text to the pics but i cant seem to add any effects to the text.
thanks,
bmac_007
Ulead Cool 3-d, it does that and a lot more. It does export as an overlay but I don't think VS8 cn import overlays. You would have to export as a completed AVI to import it into VS8.
WildFX Pro (from wildform www.wildform.com does some nice text effects and I found it pretty easy to use..encodes an avi w/ an alpha channel transparent background ... not sure if your editor supports that (it should but better to check) ...not sure how it compares to cool 3-d...
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole." -
thanks for the replies. i found out how to get it to work with i have. apparently i was in some kind of slideshow wizard and wasnt using the full program.
What is Best Software for Slideshow Presentation Videos? Cool Transitions !
By zcity1 in forum Newbie / General discussionsReplies: 1Last Post: 17th Aug 2011, 13:11 -
Adding transitions to videos with free software
By Cyber Akuma in forum EditingReplies: 61Last Post: 8th Dec 2010, 11:36 -
Help: .m2ts joining and adding transitions
By klynax in forum EditingReplies: 2Last Post: 9th Oct 2009, 14:25 -
DVD slideshow GUI transitions
By dread in forum Authoring (DVD)Replies: 1Last Post: 14th Nov 2008, 13:05 -
Adding text over original text
By stixster in forum EditingReplies: 3Last Post: 17th Jun 2008, 05:14
