  1. i have a 4x dvd-r dvd burner........and i am using compusa dvd-r 1X.......i am using CloneDVD the latest version......2.4 (whatver it is)
    when i am copying a dvd that is long.....it skipps around on the last couple of minutes.......
    I used DVDShrink and i dont have this problem.........does anybody use the use the same type of burner and CDs......and have sucessful copies with a particular software and with a dvd that is over 3 hours
  2. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    I am not sure if this is the problem but f.y.i. try not to burn to the max capicity of the blank dvd disc. That tends to give you jerky playback near the end of the video.
    Nobody likes a bunch of yackity-yack.
    Apr 2003
    Maryland
    Hey,, could it possibly does great Comp USA Disks??? Skipping at the end of video = Crappy Media!
    Solution = Get better media and don't create a file to the maximum capacity of your blank.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  4. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Yep. Crap media that has dye spread issues. Is the media ID by any chance Princo? They're notorious for that.
    May 2003
    comp usa media is princo which = crap.
  6. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Bingo.
    Ditch the Princo and get some Taiyo Yuden, Maxell, or other quality brand. Stay away from house "generic" brands because they tend to be rejects from other vendors or ultra-cheap Taiwan crap like Princo or CMC.
  7. is there a way to set the size of the dvd media output to a smaller size
  8. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Take DVDShrink off automatic sizing and you can set it to any output size you want' For safety, limit it to 4.0GB and even Princo media will usually burn OK half the time
